| 0003451 | Path | Feature | public | 2018-05-02 20:09 | 2019-01-22 03:41 |
| Target Version | 0.18 | ||||
| Summary | 0003451: Need method for working on a partial profile. | ||||
| Description | A method is needed to be able to remove material from one area of the stock profile without doing a complete profile/contour operation. There are at least two situations requiring this: 1) The user has clamped the part on the table and only wishes to machine a couple faces without profiling the entire part. For example, machining one face of a casting. 2) The profile of the part involves a very deep recess that should be cleared from the outside in rather than with 100% cutter engagement as the cutter plows through and cuts out a chunk of stock. The current workaround is for the user to create a 'helper object'. then creating a job for that object and adding appropriate operations. At a minimum this process could be automated to create the helper object seamlessly in the background and use its shape for the operation. | ||||
| 2018-05-02 20:09 | sliptonic | New Issue | |
| 2018-05-02 20:09 | sliptonic | Status | new => assigned |
| 2018-05-02 20:09 | sliptonic | Assigned To | => sliptonic |
| 2019-01-22 03:40 | sliptonic | Note Added: 0012480 | |
| 2019-01-22 03:41 | sliptonic | Status | assigned => closed |
| 2019-01-22 03:41 | sliptonic | Resolution | open => fixed |
