| 0003463 | Path | Bug | public | 2018-05-08 13:47 | 2020-10-06 22:59 |
| Summary | 0003463: Imported Path prevents creation of tool controller | ||||
| Description | When a gcode file is imported a Path object is created at the root of the document. If a Job already exists and the user tries to create a Tool Controller, the operation will fail: Traceback (most recent call last): File "D:\Downloads\download\freecad\FreeCAD_0.17\Mod\Path\PathScripts\PathToolLibraryManager.py", line 624, in copyTools if isinstance(job.Proxy, PathScripts.PathJob.ObjectJob) and job.Label == targetlist: AttributeError: 'App.DocumentObject' object has no attribute 'Proxy' | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=15&t=28603#p232438 | ||||
This only occurs if using legacy tools with an external gcode file imported with the example_pre.py preprocessor. If you use the gcode_pre.py preprocessor, the gcode becomes a custom inside the job. It can be postprocessed and is more useful. If you insist on importing gcode to a path object outside the job hierarchy, you can still use the new toolbits instead of legacy tools |
| 2018-05-08 13:47 | sliptonic | New Issue | |
| 2019-01-22 05:33 | sliptonic | Status | new => acknowledged |
| 2019-01-22 05:33 | sliptonic | Target Version | 0.18 => 0.19 |
| 2019-01-22 05:35 | sliptonic | Relationship added | child of 0003464 |
| 2020-10-06 22:59 | sliptonic | Assigned To | => sliptonic |
| 2020-10-06 22:59 | sliptonic | Status | acknowledged => closed |
| 2020-10-06 22:59 | sliptonic | Resolution | open => won't fix |
| 2020-10-06 22:59 | sliptonic | Note Added: 0014780 |
