| 0003472 | Sketcher | Feature | public | 2018-05-12 21:27 | 2018-05-23 11:50 |
| Reporter | bejant | Assigned To | abdullah | ||
| Summary | 0003472: Add 90 Degree Arc to Sketcher Polyline Mode | ||||
| Description | It would be handy to be able to create 90 degree arcs when using the Sketcher Polyline tool, so I'm asking that this behavior be added so that it is available when pressing the M key to cycle through the Polyline modes. When in the Polyline tool, after creating the first line segment, the third press of the M key cycles to a tangent arc. When placing the endpoint of this arc, it is difficult (usually impossible) to create a true 90 degree arc so that the following line segment is perpendicular to the first line segment. 1. In the common use case of starting with, let's say, a horizontal line in the Polyline tool, it is easy to place the start point of the Polyline (point #1), and then to locate the cursor so that the cursor indicates that a horizontal constraint will be created when point 0000002 is placed. 2. From here, the third M key press causes an arc to be created tangent to the first line segment when Polyline point 0000003 is placed. Try your best to move the cursor so that indicates an included angle of exactly 90 degrees, or to create the arc so that the included angle is exactly 90 degrees when placing Polyline point 0000003. 3. The next (vertical) Polyline segment placed will not be constrained as vertical, so the user has to manually apply the Vertical Constraint. 4. For a Polyline of multiple horizontal and vertical line segments connected by multiple arcs between the line segmments, the user has to add multiple H or V constraints after the Polyline is created. This feature request would fix that, and save a little time for the user. I had originally thought that the 90 degree arc should be invoked on the fourth M keypress, which is after the tangent arc and before the first perpendicular arc. Now I'm thinking that this proposed 90 degree tangent arc would be used more often than the existing tangent arc of varying included angle, and so the new 90 degree arc should be invoked on the third M keypress, and the existing tangent arc of variable included angle would be the fourth keypress, while the two existing perpendicular arcs would become M keypresses 5 and 6. Forum post (scroll towards the bottom of my post): https://forum.freecadweb.org/viewtopic.php?f=3&t=28492&start=80#p233169 | ||||
| Steps To Reproduce | Included above. | ||||
| Additional Information | Testing using my newest daily build (2 days old): OS: Ubuntu 16.04.4 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.18.13674 (Git) Build type: None Branch: master Hash: 32f089f28408479ce65a22a753bb815ffe3d45ed Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedStates (en_US) | ||||
| 2018-05-12 21:27 | bejant | New Issue | |
| 2018-05-20 19:02 | abdullah | Assigned To | => abdullah |
| 2018-05-20 19:02 | abdullah | Status | new => assigned |
| 2018-05-21 05:56 | abdullah | Note Added: 0011261 | |
| 2018-05-23 11:50 | wmayer | Status | assigned => closed |
| 2018-05-23 11:50 | wmayer | Resolution | open => fixed |
| 2018-05-23 11:50 | wmayer | Fixed in Version | => 0.18 |
| 2018-05-23 11:50 | wmayer | Note Added: 0011273 |
