| 0003502 | Path | Bug | public | 2018-06-08 19:06 | 2018-06-09 09:17 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0003502: Engraving produces wrong path | ||||
| Description | Engraving text with the `osifont_lgpl3.ttf` font (shipped with FC in the TechDraw module) produces a (seriously) wrong path. The wrongness of the path seems to depend on the absolute position of the shapestring, it is different after moving the string to the origin. Discussion: https://forum.freecadweb.org/viewtopic.php?f=15&t=29177 | ||||
The root cause was the tolerance setting for converting bezier curves and splines (0.5). In switching that I noticed that the same checks had already been implemented in PathGeom. So I changed the implementation to use that. https://github.com/FreeCAD/FreeCAD/pull/1503/commits/79db94cee2c09e5c5020971d036330434470572e |
https://github.com/FreeCAD/FreeCAD/commit/f0e6b696905d77aeef72c7bb64f94db4b1a2f1fb |
| 2018-06-08 19:06 | mlampert | New Issue | |
| 2018-06-08 20:19 | mlampert | Summary | Path rendering introduces wrong artifacts => Engraving produces wrong path |
| 2018-06-08 20:19 | mlampert | Description Updated | |
| 2018-06-09 00:07 | mlampert | Assigned To | => mlampert |
| 2018-06-09 00:07 | mlampert | Status | new => assigned |
| 2018-06-09 07:22 | mlampert | Note Added: 0011375 | |
| 2018-06-09 07:23 | mlampert | Target Version | => 0.18 |
| 2018-06-09 09:17 | wmayer | Status | assigned => closed |
| 2018-06-09 09:17 | wmayer | Resolution | open => fixed |
| 2018-06-09 09:17 | wmayer | Fixed in Version | => 0.18 |
| 2018-06-09 09:17 | wmayer | Note Added: 0011381 |
