| 0003503 | Sketcher | Bug | public | 2018-06-08 21:45 | 2018-06-09 09:16 |
| Reporter | abdullah | Assigned To | abdullah | ||
| Summary | 0003503: Failure to update solver information on addition of constraint | ||||
| Description | Sometimes on addition of a constraint, the solver information is not accurate. | ||||
| Steps To Reproduce | 1. Load the attached sketch 2. Delete the symmetry constraint 3. Rotate one endpoint of the arc so that it is not in the position of symmetry 4. Reapply the symmetry constraint. The result is a fully constraint sketch, which is false. Just drag one endpoint of the arc and it will move. | ||||
| Additional Information | The example is just one example where the problem is very apparent as it shows "fully constraint". It also happens in other situations where simply the DoFs reported are wrong. | ||||
https://github.com/FreeCAD/FreeCAD/pull/1502 |
@triplus Finally this one is fixed. It was not a solver problem after all, just a failure to update the solver information. |
https://github.com/FreeCAD/FreeCAD/commit/d6d26b6a8983b7a0678d268ab98e218d34995f26 |
| 2018-06-08 21:45 | abdullah | New Issue | |
| 2018-06-08 21:45 | abdullah | Status | new => assigned |
| 2018-06-08 21:45 | abdullah | Assigned To | => abdullah |
| 2018-06-08 21:45 | abdullah | File Added: arc_sym.fcstd | |
| 2018-06-08 21:51 | abdullah | File Added: wrong_fully_constraint1.png | |
| 2018-06-08 21:52 | abdullah | Note Added: 0011369 | |
| 2018-06-08 21:53 | abdullah | Note Added: 0011370 | |
| 2018-06-09 09:16 | wmayer | Status | assigned => closed |
| 2018-06-09 09:16 | wmayer | Resolution | open => fixed |
| 2018-06-09 09:16 | wmayer | Fixed in Version | => 0.18 |
| 2018-06-09 09:16 | wmayer | Note Added: 0011380 |
