| 0003515 | Expressions | Bug | public | 2018-06-18 00:22 | 2019-01-13 23:22 |
| Reporter | bejant | Assigned To | wmayer | ||
| Priority | low | Severity | trivial | Reproducibility | always |
| Platform | PC | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0003515: Changing Name of Spreadsheet in History Tree Does Not Trigger Name Update in Tab at Bottom of 3D Window | ||||
| Description | Forum post: https://forum.freecadweb.org/viewtopic.php?f=3&t=28825#p239887 | ||||
| Steps To Reproduce | Create a Spreadsheet; it will be named "Spreadsheet" in the history tree. Double-click Spreadsheet in the history tree to open it for editing; this opens a new tab below the 3D view named "Spreadsheet". Select Spreadsheet in the history tree and re-name it. Issue: After renaming, the tab at the bottom of the 3D view does not update with the new name. Instead it is named "Spreadsheet*". After closing the "Spreadsheet*" tab, then opening the renamed spreadsheet, shows the correct name in the tab below the 3D view. | ||||
| Additional Information | Tested using OS: Ubuntu 16.04.4 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.18.13934 (Git) Build type: None Branch: master Hash: b77b77c0def23f2abb9b0c96ed9c50076906be6a Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | 0.18, spreadsheet | ||||
| 2018-06-18 00:22 | bejant | New Issue | |
| 2018-06-18 00:22 | bejant | Tag Attached: 0.18 | |
| 2018-06-18 00:22 | bejant | Tag Attached: spreadsheet | |
| 2019-01-13 23:22 | wmayer | Assigned To | => wmayer |
| 2019-01-13 23:22 | wmayer | Status | new => closed |
| 2019-01-13 23:22 | wmayer | Resolution | open => fixed |
| 2019-01-13 23:22 | wmayer | Fixed in Version | => 0.18 |
| 2019-01-13 23:22 | wmayer | Note Added: 0012427 |
