| Reporter | mlampert | Assigned To | mlampert | |
| Status | closed | Resolution | fixed | |
| Product Version | 0.18 | |
| Target Version | 0.18 | |
| Summary | 0003548: PocketShape ignores holes in selected base model faces |
| Description | Change 135ede46fe added the use of TechDraw::findShapeOutline, which does not return wires for holes. |
| Steps To Reproduce | Create a solid with a hole, use PocketShape to plane the top - although the hole is not added to the base model the generate path includes the area of the hole. |
| Tags | No tags attached. |
| FreeCAD Information | |
