| 0000357 | FreeCAD | Bug | public | 2011-05-25 12:22 | 2011-09-07 07:07 |
| Summary | 0000357: 'Duplicate Selection' not copying all attributes | ||||
| Description | If you create a 2d drawing element such as a multiline, or a regular polygon and then select it and duplicate it with the Edit -> 'Duplicate Selection' the new object does not list all of the properties in the property view window. For example, on a regular polygon you can change the radius, but on the duplicated version the radius setting is not available. I checked it for some of the 3d parametric shapes (specifically the cylinder and the torus, and they both worked correctly (all parameters were visible on both the original and the duplicate. Taken from https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=10&t=1017&p=7802#p7802 | ||||
| Steps To Reproduce | Make a circle in Draft and do Duplicate Selection | ||||
| 2011-05-25 12:22 | wmayer | New Issue | |
| 2011-05-25 12:22 | wmayer | Status | new => assigned |
| 2011-05-25 12:22 | wmayer | Assigned To | => wmayer |
| 2011-09-07 07:07 | wmayer | Note Added: 0001049 | |
| 2011-09-07 07:07 | wmayer | Status | assigned => closed |
| 2011-09-07 07:07 | wmayer | Resolution | open => fixed |
| 2011-09-07 07:07 | wmayer | Fixed in Version | => 0.12 |
