| 0003575 | TechDraw | Feature | public | 2018-08-31 13:12 | 2022-02-02 17:07 |
| Reporter | Kunda1 | Assigned To | |||
| Priority | none | Severity | feature | Reproducibility | N/A |
| Summary | 0003575: TechDraw: Don't recompute on text changes | ||||
| Description | Reference: https://forum.freecadweb.org/viewtopic.php?f=3&t=30524&p=253695#p253670 | ||||
| Tags | #pending | ||||
I don't understand this one. What text is being changed? Is Page KeepUpToDate property set to false to avoid recompute/redraw? |
The problem is the following: when we're making a technical draw of some machine, we need to specify a lot of components characteristics and names in order to make it easily understandable; in example the table of components, welding type, surface finishing and so forth; in the designing process we change continuously those characteristics and text, in this sense is annoying have to recompute a whole text if you only need to change a section of it: an incorrect letter or number, recompute a whole 50 components table for only one incorrect part. Try to make those texts individual boxes, like Inventor. |
This may be a SpreadsheetWB issue. See forum post |
@wmayer can you weigh in ? |
Is there an example project available to test the behaviour? |
Here is the one I've been using. Still don't know what text the OP is changing. |
How can this be "confirmed" if we don't know what the OP is talking about? |
@wandererfan hmm, looks like I did that. Not sure what my rationale was at the time. Apologies. |
@wandererfan though, instead as marking it as 'new' better to mark as 'feedback' because we are awaiting feedback from OP in that case |
@kunda1 - thought I did make it "feedback". getting old. |
@jango ping |
The forum discussion is marked as "Solved". Can we close this ticket? |
This ticket has been migrated to GitHub as issue 5803. |
| 2018-08-31 13:12 | Kunda1 | New Issue | |
| 2018-10-05 12:46 | wandererfan | Note Added: 0011929 | |
| 2018-10-05 12:46 | wandererfan | Status | new => feedback |
| 2019-01-04 18:59 | Kunda1 | Tag Attached: #pending | |
| 2019-02-21 04:39 | jango | Note Added: 0012709 | |
| 2019-02-23 13:36 | wandererfan | Note Added: 0012730 | |
| 2019-03-03 14:09 | Kunda1 | Note Added: 0012829 | |
| 2019-03-03 14:09 | Kunda1 | Status | feedback => new |
| 2019-03-03 14:10 | Kunda1 | Note Edited: 0012730 | |
| 2019-03-03 14:11 | Kunda1 | Status | new => confirmed |
| 2019-03-03 14:11 | Kunda1 | Product Version | => 0.18 |
| 2019-03-04 09:24 | wmayer | Note Added: 0012845 | |
| 2019-03-04 13:55 | wandererfan | File Added: ssRecompute.FCStd | |
| 2019-03-04 13:55 | wandererfan | Note Added: 0012848 | |
| 2019-07-19 15:26 | wandererfan | Status | confirmed => feedback |
| 2019-07-19 15:26 | wandererfan | Note Added: 0013367 | |
| 2019-07-19 19:56 | Kunda1 | Note Added: 0013368 | |
| 2019-07-19 19:56 | Kunda1 | Status | feedback => new |
| 2019-07-19 19:57 | Kunda1 | Status | new => feedback |
| 2019-07-19 19:57 | Kunda1 | Note Added: 0013369 | |
| 2019-07-20 00:16 | wandererfan | Note Added: 0013370 | |
| 2022-01-19 17:46 | Kunda1 | Note Added: 0016230 | |
| 2022-01-19 17:46 | Kunda1 | Status | feedback => new |
| 2022-02-02 17:07 | wandererfan | Note Added: 0016337 |
