| 0003595 | Path | Bug | public | 2018-09-15 07:49 | 2018-09-17 08:26 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0003595: Cannot set extent of "Stock Create Box" | ||||
| Description | When setting the size of the box it accepts those values but resets to the bounding box of the base models when the Job editor is invoked again. | ||||
| Steps To Reproduce | * Create a Job * Use stock "Create Box" * edit Length/Width or Height * press "OK" * check size of "Job.Stock" - it has the set size * edit Job again (double click) and observer that the extent is reset to the bounding box | ||||
| 2018-09-15 07:49 | mlampert | New Issue | |
| 2018-09-15 07:49 | mlampert | Status | new => assigned |
| 2018-09-15 07:49 | mlampert | Assigned To | => mlampert |
| 2018-09-16 02:25 | mlampert | Assigned To | mlampert => |
| 2018-09-16 02:26 | mlampert | Assigned To | => mlampert |
| 2018-09-16 02:26 | mlampert | Note Added: 0011750 | |
| 2018-09-17 08:26 | wmayer | Status | assigned => closed |
| 2018-09-17 08:26 | wmayer | Resolution | open => fixed |
| 2018-09-17 08:26 | wmayer | Fixed in Version | => 0.18 |
