| 0000360 | FreeCAD | Feature | public | 2011-05-26 06:52 | 2011-08-31 07:32 |
| Summary | 0000360: copy visual attributes on parametric operations | ||||
| Description | Wen doing a operation which has one or more sources (like boolean or pad) copy the visual attributes (like color transparency) to the result object once. Cause the Source is most likely hidden after ward. That can be done in the python code of the corresponding Gui::Command right after the object is created. Then the ViewProvider is also already existent. | ||||
| 2011-05-26 06:52 |
New Issue | |
| 2011-05-26 06:52 |
| 2011-08-31 07:32 | wmayer | Note Added: 0001021 | |
| 2011-08-31 07:32 | wmayer | Status | acknowledged => closed |
| 2011-08-31 07:32 | wmayer | Resolution | open => fixed |
| 2011-08-31 07:32 | wmayer | Fixed in Version | => 0.12 |
