| 0003601 | FreeCAD | Bug | public | 2018-09-17 16:06 | 2018-09-20 10:55 |
| Reporter | freedman | Assigned To | wmayer | ||
| Summary | 0003601: Keeping "Display properties" window open affects naming of objects/bodies, persistent thru new file creation. | ||||
| Description | Naming and renaming objects in the tree is a basic operation, if the "Display properties" window is left open and renaming an object in the tree occurs the program locks into a state that disallows future renaming. Once this problem occurs it is persistent even if the file is closed and a new file is created, naming objects in the tree won't work. This problem occurs in both Part and Part design. https://forum.freecad.org/viewtopic.php?f=8&t=30965 | ||||
| Steps To Reproduce | In Part design; Create a new file and a Body. Right-click the Body in the tree and select Appearance, the "Display properties " opens, keep that window open. Select Body in the tree and rename it. That's where the problem starts, when I hit the Enter key the Body text field does not close correctly. From this point on renaming fields in all Bodies does not work or does not update the Properties correctly. | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14709 (Git) Build type: Release Branch: master Hash: faad5ea27301cb7af393a25d317c406d3098bafe Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedStates (en_US) | ||||
| 2018-09-17 16:06 | freedman | New Issue | |
| 2018-09-20 10:55 | wmayer | Assigned To | => wmayer |
| 2018-09-20 10:55 | wmayer | Status | new => closed |
| 2018-09-20 10:55 | wmayer | Resolution | open => fixed |
| 2018-09-20 10:55 | wmayer | Fixed in Version | => 0.18 |
| 2018-09-20 10:55 | wmayer | Note Added: 0011796 |
