| 0003609 | TechDraw | Feature | public | 2018-09-24 04:44 | 2021-02-06 06:38 |
| Reporter | normandc | Assigned To | |||
| Summary | 0003609: TechDraw - Auxiliary View | ||||
| Description | Per Wikipedia: https://en.wikipedia.org/wiki/Engineering_drawing#Auxiliary_views The auxiliary view has a "viewing plane indicator" (really no clue how it's called) which usually is a dotted line with arrows, similar to a section view. It may depend on drawing standards. The auxiliary view is usally linked and aligned to its parent view, although it may be possible to break the alignment if there is not enough space on the page besides the parent view. A possible work flow would be to select a linear edge on a view then launch the auxiliary view tool. A FreeCAD file with TechDraw page is attached, with a pseudo auxiliary view made with the standard NewView tool. Attached svg was edited to manually add the plane indicator with view label. | ||||
