| 0003611 | PartDesign | Bug | public | 2018-09-25 06:00 | 2018-09-25 09:16 |
| Reporter | chrisb | Assigned To | wmayer | ||
| Summary | 0003611: Linear pattern: "Select reference" does near to nothing | ||||
| Description | The "Select reference" option to define the direction of the pattern does neither work on Sketches, nor on DatumLines or edges. See forum discussion | ||||
| Steps To Reproduce | - load file attached to the forum - double click linear pattern - for Direction choose "Select reference" - select the DatumLine expected behaviour: Pattern is aligned diagonally The last two steps with the same expectation hold for the diagonals of the sketch and the solid. | ||||
| 2018-09-25 06:00 | chrisb | New Issue | |
| 2018-09-25 09:16 | wmayer | Assigned To | => wmayer |
| 2018-09-25 09:16 | wmayer | Status | new => closed |
| 2018-09-25 09:16 | wmayer | Resolution | open => fixed |
| 2018-09-25 09:16 | wmayer | Fixed in Version | => 0.18 |
| 2018-09-25 09:16 | wmayer | Note Added: 0011831 |
