| 0003617 | FEM | Bug | public | 2018-09-25 21:30 | 2019-01-14 18:37 |
| Reporter | berndhahnebach | Assigned To | ickby | ||
| Summary | 0003617: FEM, post processing, vtk mesh, it is not possible to create a vtk mesh with gaps | ||||
| Description | https://forum.freecadweb.org/viewtopic.php?f=18&t=27105&start=70#p225490 | ||||
| Steps To Reproduce | - open FEM 2D example - select solver - change "Beam Shell Result Output 3D" to true - rerun analysis - check Abs displacement colors in standard result object, they look fine. - select the 3D solid result object - create vtk pipe - some error in report view is printed - double click on the pipeline - set mode "Surface wit edges" - set field to "Displacement" - set vector to "Magnitude" - this does not look to be the right coloring ... to reproduce by Python (tested with FreeCAD 0.18.15607) use: | ||||
| related to | 0002873 | closed | berndhahnebach | FEM, mesh, unv writer, do not renumbering on file writing |
the code ... https://github.com/FreeCAD/FreeCAD/blob/a0ff629747d5d73567075821852a8cdaadcf51c5/src/Mod/Fem/App/FemVTKTools.cpp#L445-L462 |
If the FreeCAD file is saved and reopened the problem could be even worse, because of 0002873. But both are totally independent! |
Problem are the not continuous node ids in the freecad mesh. In general the FEM result property stores all results for the individual mesh nodes by index, assuming index==id. Hence Node 1 result is in result vector at position 1. However, when the node ids are not continuous in the freecad mesh, e.g. there are 3 nodes but ids are [0 1 5], that mapping does not work for VTK anymore. The reason is that in VTK node ids must be continuous, the example mesh would result in the following VTK nodes [0 1 2 3 4 5] with ids 2,3,4 existing but not used by any elements. Now with index==id the results would be assigned to ids [0 1 2] instead of [0 1 5], which results in the display error. The solution is to remove the assumption index==id and use the correct note id for each result value: https://github.com/ickby/FreeCAD_sf_master/commit/605edeecb2152130395177d0ae4828d6e1c4b12e @berndhahnebach Could you do some regression testing with this fix? |
https://github.com/FreeCAD/FreeCAD/commit/16435205d409353cb2a49ee65bf83031c06be4f8 |
| 2018-09-25 21:30 | berndhahnebach | New Issue | |
| 2018-09-25 21:30 | berndhahnebach | Status | new => confirmed |
| 2018-09-26 21:25 | berndhahnebach | Note Added: 0011860 | |
| 2018-09-26 21:28 | berndhahnebach | Note Added: 0011861 | |
| 2018-09-26 21:28 | berndhahnebach | Note Edited: 0011861 | |
| 2018-09-26 21:29 | berndhahnebach | Note Edited: 0011861 | |
| 2019-01-03 09:21 | ickby | Note Added: 0012363 | |
| 2019-01-11 06:21 | berndhahnebach | Steps to Reproduce Updated | |
| 2019-01-11 06:58 | berndhahnebach | Steps to Reproduce Updated | |
| 2019-01-11 06:59 | berndhahnebach | Steps to Reproduce Updated | |
| 2019-01-14 15:43 | wmayer | Relationship added | related to 0002873 |
| 2019-01-14 18:37 | wmayer | Assigned To | => ickby |
| 2019-01-14 18:37 | wmayer | Status | confirmed => closed |
| 2019-01-14 18:37 | wmayer | Resolution | open => fixed |
| 2019-01-14 18:37 | wmayer | Fixed in Version | => 0.18 |
| 2019-01-14 18:37 | wmayer | Note Added: 0012431 |
