| 0003618 | FEM | Bug | public | 2018-09-26 16:12 | 2018-09-26 18:00 |
| Reporter | berndhahnebach | Assigned To | wmayer | ||
| Summary | 0003618: FEM, GUI, mesh view provider, highlighted node show wrong node number on selection | ||||
| Description | see forum post https://forum.freecadweb.org/viewtopic.php?f=10&t=31150&p=258746#p258746 - open the file from first post - select the node shown in the screen in post (it is Node 7) - run the following code to highlight Node7 -
- the node should be green- again select the node, it will be Node1 and no longer Node7 - run the following code to delete the highligting
- select the node, it will be Node7 again | ||||
| 2018-09-26 16:12 | berndhahnebach | New Issue | |
| 2018-09-26 16:12 | berndhahnebach | Status | new => confirmed |
| 2018-09-26 18:00 | wmayer | Assigned To | => wmayer |
| 2018-09-26 18:00 | wmayer | Status | confirmed => closed |
| 2018-09-26 18:00 | wmayer | Resolution | open => fixed |
| 2018-09-26 18:00 | wmayer | Fixed in Version | => 0.18 |
| 2018-09-26 18:00 | wmayer | Note Added: 0011857 |
