| 0003635 | GCS | General | public | 2018-10-11 15:03 | 2021-02-06 06:31 |
| Summary | 0003635: Solver does not use point-line-tangency in all possible cases | ||||
| Description | Forum discussion | ||||
Here is a minimal example to study the behavior. The sketch has an external geometry to a Part point that lays 0.01 nm away from the Y-axis. An arc that has a coincidence constraint to this point and a tangent constraint to the Y-axis is frozen and can not be moved anymore. Tolerance values in this magnitude may happen for external geometries. |
May be connected with inter line tangency as described in this forum post. |
This ticket has been migrated to GitHub as issue 5818. |
| 2018-10-11 15:03 | chrisb | New Issue | |
| 2018-10-11 15:03 | chrisb | Status | new => assigned |
| 2018-10-11 15:03 | chrisb | Assigned To | => abdullah |
| 2018-10-11 15:05 | chrisb | Project | Sketcher => GCS |
| 2018-10-11 15:05 | chrisb | Category | Feature => General |
| 2018-10-12 19:18 | ulrich1a | File Added: minimal_sketch_freeze.fcstd | |
| 2018-10-12 19:18 | ulrich1a | Note Added: 0012014 | |
| 2018-11-02 00:34 | chrisb | Relationship added | related to 0003666 |
| 2018-11-02 00:36 | chrisb | Relationship replaced | has duplicate 0003666 |
| 2018-11-02 00:37 | chrisb | Note Added: 0012129 | |
| 2020-11-10 12:56 | abdullah | Target Version | 0.19 => 0.20 |
