| 0003649 | Sketcher | Bug | public | 2018-10-24 08:33 | 2021-02-06 05:55 |
| Priority | low | Severity | tweak | Reproducibility | always |
| Summary | 0003649: Improve handling of block constraint if dimensional constraints are involved | ||||
| Description | If a block constraint is applied after a dimensional constraint it is possible to change the value of the dimension but the block constraint prohibits the change. Such a sketch looks inconsistent. This could be solved e.g. by - appropriate solver message - notify the user - change the dimensional constraint to a driven (blue) one See forum discussion | ||||
Consider making the dimensional constraints reference and moving them after the block constraint. This combination should trigger a solver conflict message if afterwards the user actively tries to change it. |
This ticket has been migrated to GitHub as issue 5823. |
| 2018-10-24 08:33 | chrisb | New Issue | |
| 2018-10-24 08:33 | chrisb | Status | new => assigned |
| 2018-10-24 08:33 | chrisb | Assigned To | => abdullah |
| 2018-10-28 14:33 | abdullah | Note Added: 0012109 | |
| 2018-11-16 19:07 | abdullah | Target Version | => 0.19 |
| 2020-11-09 18:06 | abdullah | Target Version | 0.19 => 0.20 |
| 2021-02-06 05:55 | abdullah | Target Version | => 0.20 |
