| 0000365 | FreeCAD | Bug | public | 2011-05-28 15:22 | 2011-10-13 17:45 |
| Summary | 0000365: Coincident+ tangent constrain doesn't work well (Sketcher) | ||||
| Description | I've tried join arc and line with two constrains: coincident (point on line and on arc) and tangent. Unfortunately it very often works in wrong way (attached picture). When I'm trying join arc with two lines it never works well. Additionaly sometimes FreeCAD hangs. FC 4526 | ||||
2011-05-28 15:22
Yea, confirm. A lot work still in Sketcher. Will take a while... |
is it better with the new solver? could you try the current svn version? |
Is much better (r4692)! Constrains works without error. But there is another issue. When I try drag point (eg. end of arc) FreeCAD freeze and consume 100% CPU |
It quite strange but drag point problem appears only under Ubuntu (natty+libeigen3-dev from oneric). Under Windows everything works ok. |
I am using Ubuntu (lucid) and I cannot confirm the problem. Try a fresh build or the PPA packages. |
the problem also appears under Kubuntu (natty) fresh PPA. Under Windows XP everything works ok. |
changed fixed version to 0.12 |
| 2011-05-28 15:22 | unauthenticated | New Issue | |
| 2011-05-28 15:22 | unauthenticated | File Added: fcbug.jpg | |
| 2011-06-24 15:29 |
Status | new => assigned |
| 2011-06-24 15:29 |
Assigned To | => Jriegel |
| 2011-06-24 15:30 |
Note Added: 0000912 | |
| 2011-07-29 08:47 | logari81 | Note Added: 0000955 | |
| 2011-07-29 15:25 | unauthenticated | Note Added: 0000956 | |
| 2011-07-31 06:38 | unauthenticated | Note Added: 0000960 | |
| 2011-07-31 07:41 | logari81 | Note Added: 0000961 | |
| 2011-07-31 16:12 | unauthenticated | Note Added: 0000965 | |
| 2011-09-06 07:43 | logari81 | Status | assigned => closed |
| 2011-09-06 07:43 | logari81 | Resolution | open => fixed |
| 2011-09-06 07:43 | logari81 | Fixed in Version | => trunk |
| 2011-10-13 17:45 | yorik | Status | closed => feedback |
| 2011-10-13 17:45 | yorik | Resolution | fixed => reopened |
| 2011-10-13 17:45 | yorik | Note Added: 0001149 | |
| 2011-10-13 17:45 | yorik | Status | feedback => closed |
| 2011-10-13 17:45 | yorik | Resolution | reopened => fixed |
| 2011-10-13 17:45 | yorik | Fixed in Version | trunk => 0.12 |
