| 0000366 | FreeCAD | Feature | public | 2011-05-29 13:47 | 2011-09-17 12:54 |
| Target Version | 0.12 | Fixed in Version | 0.12 | ||
| Summary | 0000366: Add an option to select base objects after Draft copy operation | ||||
| Description | Add an option to select base objects after Draft copy operation, instead of selecting the copied objects, so the same base objects can easily be copied again somewhere else. | ||||
Done in r4530, but still not effective because the left click in the viewport to place the copy causes freecad to wipe the selection. Must add a switch somewhere... |
Actually the new delayed commit system resolved the remaining problem, so this is done! |
| 2011-05-29 13:47 | yorik | New Issue | |
| 2011-05-29 13:47 | yorik | Status | new => assigned |
| 2011-05-29 13:47 | yorik | Assigned To | => yorik |
| 2011-05-29 21:26 | yorik | Note Added: 0000871 | |
| 2011-05-29 21:27 | yorik | Note Edited: 0000871 | |
| 2011-09-17 12:54 | yorik | Note Added: 0001115 | |
| 2011-09-17 12:54 | yorik | Status | assigned => closed |
| 2011-09-17 12:54 | yorik | Resolution | open => fixed |
| 2011-09-17 12:54 | yorik | Fixed in Version | => 0.12 |
