| 0003665 | Path | Bug | public | 2018-11-01 13:52 | 2019-01-22 19:29 |
| Reporter | jurij | Assigned To | sliptonic | ||
| Summary | 0003665: Material Allowance is not working | ||||
| Description | In Face operation the Material Allowance parameter is not taken into account using Line, Grid, Triangle patterns. The same problem exists with Pocket Shape operation regarding Pass Extension parameter. Attached test case with applied patch which should correct the behaviour is attached. I have reported this on the forum but in more that a week I haven't got any replies. https://forum.freecadweb.org/viewtopic.php?f=15&t=31762 | ||||
| Steps To Reproduce | Make a Face operation. Select Line, Grid or Triangle pattern. Select Material Allowance different from zero. It doesn't have any effect. Make Pocket Shape operation. Select Line, Grid or Triangle pattern. Select Pass Extension different from zero. It doesn't have any effect. | ||||
| Additional Information | OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14993 (Git) Build type: Debug Branch: master Hash: 1e6818b6fbf86ad08d8fc85252dddcae8891dd54 Python version: 2.7.15 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1.oce-0.18 Locale: English/UnitedKingdom (en_GB) | ||||
patch.txt (1,046 bytes)
--- ../../../../../FreeCAD-master/src/Mod/Path/App/Area.cpp 2018-10-23 11:47:11.000000000 +0100
+++ Area.cpp 2018-10-23 13:37:58.611154476 +0100
@@ -2059,6 +2059,8 @@
shift = 0.0; //Line pattern does not support shift
Point center(box.Centre());
double r = box.Radius()+stepover;
+ if ( extra_offset > 0 )
+ r += extra_offset;
int steps = (int)ceil(r*2.0/stepover);
for(int i=0;i<count;++i) {
double a = angle + angles[i];
@@ -2080,7 +2082,7 @@
PARAM_ENUM_CONVERT(AREA_MY,PARAM_FNAME,PARAM_ENUM_EXCEPT,AREA_PARAMS_CLIPPER_FILL);
PARAM_ENUM_CONVERT(AREA_MY,PARAM_FNAME,PARAM_ENUM_EXCEPT,AREA_PARAMS_OFFSET_CONF);
auto area = *myArea;
- area.OffsetWithClipper(-tool_radius,JoinType,EndType,
+ area.OffsetWithClipper(-tool_radius-extra_offset,JoinType,EndType,
myParams.MiterLimit,myParams.RoundPrecision);
out.Clip(toClipperOp(OperationIntersection),&area,SubjectFill,ClipFill);
done = true;
Sorry this got overlooked so long. Patch applied. Submitting with next PR. |
https://github.com/FreeCAD/FreeCAD/commit/96dee91d5e7d7fd37f43a4dcf406a120ae1f1b8a |
| 2018-11-01 13:52 | jurij | New Issue | |
| 2018-11-01 13:52 | jurij | File Added: patch.txt | |
| 2018-11-01 13:52 | jurij | File Added: offset.fcstd | |
| 2019-01-22 04:30 | sliptonic | Note Added: 0012484 | |
| 2019-01-22 05:06 | sliptonic | Status | new => resolved |
| 2019-01-22 19:29 | wmayer | Assigned To | => sliptonic |
| 2019-01-22 19:29 | wmayer | Status | resolved => closed |
| 2019-01-22 19:29 | wmayer | Resolution | open => fixed |
| 2019-01-22 19:29 | wmayer | Fixed in Version | => 0.18 |
| 2019-01-22 19:29 | wmayer | Note Added: 0012488 |
