| 0003695 | Path | Bug | public | 2018-11-16 18:47 | 2019-01-22 04:02 |
| Reporter | TheRainHarvester | Assigned To | sliptonic | ||
| Platform | win | OS | 8.1 | OS Version | Pro |
| Summary | 0003695: "Simple Copy Button" (ie non-parametric copy), doesn't work. | ||||
| Description | Usage scenario: I want to cut a lot of the same parts on CNC. I have a Helix001 path. Copying the path with the "Simple Copy Button" does not produce gcode correctly. (it produces repeated cuts in the same location even when placement is different.) | ||||
| Steps To Reproduce | Open attached file Notice the lower paths (which are the copy). The copy shows the correct placement. Click "post process" and save the file. In the file, Notice that the path is not correctly displaced downward but instead repeats the same locations. You can see this line is repeated twice: G2 X15.2730 Y-19.9421 Z-0.3667 I-1.4500 J0.0000 F500.00 The second occurrence should be placed down in the Y direction. You can also see this if viewing the file in a gcode simulator (Camotics). | ||||
| Additional Information | OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15214 (Git) Build type: Release Branch: master Hash: b3721f8613b975be13e1801f499fa06f6f0ad836 Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/UnitedStates (en_US) | ||||
This is a misunderstanding of how simple copy works. It isn't intended to make multiple copies in different locations. It's intended to make a non-parametric copy of a path which can then be hand-edited. Also, the placement property of Paths only affects how gcode is visualized in the 3D workspace not where it is generated in the machine coordinate space. For your use-case, a better approach is to use Path-Array. if the copies can be described in a polar or linear array. Otherwise, you might have to make copies of your base object and use a multi-base job. |
| 2018-11-16 18:47 | TheRainHarvester | New Issue | |
| 2018-11-16 18:47 | TheRainHarvester | File Added: BugCopyPathThenDisplaceDoesntWork.FCStd | |
| 2019-01-22 04:02 | sliptonic | Assigned To | => sliptonic |
| 2019-01-22 04:02 | sliptonic | Status | new => closed |
| 2019-01-22 04:02 | sliptonic | Resolution | open => not fixable |
| 2019-01-22 04:02 | sliptonic | Note Added: 0012482 |
