| 0003713 | Part | Feature | public | 2018-12-03 14:20 | 2021-12-29 05:35 |
| Reporter | paullee | Assigned To | |||
| Platform | All | OS | All | OS Version | n/a |
| Summary | 0003713: Sweep Missing Path / Spine in Dialog or Properties | ||||
| Description | Discussion in forum Sweep Missing Path / Spine in Dialog or Properties:- "...want to edit a sweep object. In the property dialog, there is 'Sections' to change, but there is none for the ''path' or 'spine'. Double-click it return a translation dialog only. Need to access through python sweep.spine attribute."
| Steps To Reproduce | See above copy of forum discussion. | ||||
See more discussion and suggestion here |
@uwestoehr this sounds like something you've worked on during the 0.20 dev cycle. Can you comment on the status of this report? |
This ticket has been migrated to GitHub as issue 5842. |
