| 0003723 | Part | Feature | public | 2018-12-11 00:54 | 2019-03-09 21:27 |
| Reporter | planeanimal05 | Assigned To | DeepSOIC | ||
| Platform | Personal computer (PC) | OS | Windows | OS Version | 7 |
| Summary | 0003723: Part->Boolean->slice | ||||
| Description | Forum -> https://forum.freecadweb.org/viewtopic.php?f=8&t=32716 Consider an imported BOX_TOP.stl file which is imported and converted to a solid (Top (Solid)). There is a need to re-design a portion of the Top (Solid). This involves cutting a protrusion and stretching it. This video demonstrates https://youtu.be/36RPTGBAark The steps needed make the cut create a "Slice" entry in the info tree. The feature/enhancement would be to have FreeCAD populate the tree with the entries "Top1 (Solid)" and "Top2 (Solid)" made visible so that the user can continue to edit the shapes. Thank you | ||||
| Steps To Reproduce | Not a bug. No change to steps needed to perform the slice. Only the resulting info feedback to the user need be added. | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13541 (Git) Build type: Release Branch: releases/FreeCAD-0-17 Hash: 9948ee4f1570df9216862a79705afb367b2c6ffb Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 | ||||
| Tags | boolean, Part | ||||
Fixed with this set of commits: https://github.com/FreeCAD/FreeCAD/commits?author=DeepSOIC&since=2018-12-14&until=2019-01-01 |
| 2018-12-11 00:54 | planeanimal05 | New Issue | |
| 2018-12-11 00:54 | planeanimal05 | Tag Attached: boolean | |
| 2018-12-11 00:54 | planeanimal05 | Tag Attached: Part | |
| 2019-03-09 21:27 | normandc | Assigned To | => DeepSOIC |
| 2019-03-09 21:27 | normandc | Status | new => closed |
| 2019-03-09 21:27 | normandc | Resolution | open => fixed |
| 2019-03-09 21:27 | normandc | Fixed in Version | => 0.18 |
| 2019-03-09 21:27 | normandc | Note Added: 0012871 |
