0003725 | FreeCAD | Bug | public | 2018-12-12 09:15 | 2021-03-13 21:37 |
Reporter | mnv | Assigned To | |||
Priority | normal | Severity | major | Reproducibility | always |
Status | feedback | Resolution | open | ||
Product Version | 0.18 | ||||
Target Version | 0.20 | ||||
Summary | 0003725: Changing of the transparency parameter on Radeon GPU | ||||
Description | I got problem with changing transparency parameter with FreeCAD based on Qt5. You can see result of the applying transparency value for model on the attachment screenshot. This problem was reproduced on AMD Radeon HD7700, AMD Radeon HD6670 and AMD Radeon R9 380. Graphic drivers were updated on the last available version. | ||||
Steps To Reproduce | 1. Run FreeCAD 2. Open any model 3. Select part of model or full model 4. Change Transparency value | ||||
Additional Information | FreeCAD About Info: OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15299 (Git) Build type: Release Branch: master Hash: 5217b245b4f98cf1e3f63ecfe20e379fe4923d80 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
Tags | #pending-forum, display | ||||
FreeCAD Information | |||||
Please post a link to this ticket on the forum to discuss with the community |
https://forum.freecadweb.org/viewtopic.php?f=3&t=32787 |
@mnv is this solved in a higher version of Qt5 ? |
This ticket has been migrated to GitHub as issue 5845. |
2018-12-12 09:15 | mnv | New Issue | |
2018-12-12 09:15 | mnv | File Added: EnginePart.png | |
2018-12-12 23:48 | Kunda1 | Status | new => feedback |
2018-12-12 23:48 | Kunda1 | Note Added: 0012266 | |
2018-12-14 09:21 | mnv | Note Added: 0012270 | |
2018-12-14 09:21 | mnv | Status | feedback => new |
2021-02-06 06:50 | abdullah | Target Version | => 0.20 |
2021-03-13 21:36 | Kunda1 | Status | new => feedback |
2021-03-13 21:36 | Kunda1 | Note Added: 0015510 | |
2021-03-13 21:36 | Kunda1 | Tag Attached: display | |
2021-03-13 21:37 | Kunda1 | Tag Attached: #pending-forum |
