| 0000373 | FreeCAD | Bug | public | 2011-06-08 21:59 | 2011-10-14 17:30 |
| Reporter | tombrown19 | Assigned To | yorik | ||
| Summary | 0000373: 2d Drafting bug - Should not allow the deletion of an object that is currently being drawn | ||||
| Description | AMD 9850 Foxconn A7DA-S (790GX/SB750) 8GB RAM 17 x 2TB WD Caviar Green (16 in a ZFS - ZRAID1 array) 1 x 64GB Kingston SSDNow V+ SNVP325S264GB: Software: Distribution: ArchLinux Kernel: 2.6.37 (vanilla) xorg: xorg-server 1.10.2-1 KDE: 4.6.3-1 FreeCAD: 0.12 (4545) Description: FreeCAD allows for the deletion of an object while it is being created. Once deleted, you cannot finish editing it or close the creation process. Repeatability: - Open the file I've attached - Select 2d Drawing workbench - Select Draft - line tool - From the objects view, delete the line that was just created - You now cannot get out of the editing stage of creating the line object | ||||
2011-06-08 21:59
Indeed that should be fixed! When the edit mode will be accessable to python I'll put all the Draft creation commands in editmode, thus preventing their object from being deleted while the command is active, but I'll try to do something provisory... |
done in r5023 |
| 2011-06-08 21:59 | tombrown19 | New Issue | |
| 2011-06-08 21:59 | tombrown19 | File Added: House.fcstd | |
| 2011-06-14 17:37 | yorik | Note Added: 0000899 | |
| 2011-06-14 17:37 | yorik | Status | new => assigned |
| 2011-06-14 17:37 | yorik | Assigned To | => yorik |
| 2011-10-14 17:30 | yorik | Note Added: 0001154 | |
| 2011-10-14 17:30 | yorik | Status | assigned => closed |
| 2011-10-14 17:30 | yorik | Resolution | open => fixed |
| 2011-10-14 17:30 | yorik | Fixed in Version | => 0.12 |
