| 0003731 | GCS | General | public | 2018-12-15 18:38 | 2021-02-06 06:31 |
| Reporter | abdullah | Assigned To | abdullah | ||
| Summary | 0003731: SQP usage / debug information | ||||
| Description | SQP appears not to be used for movement. It is unclear why it uses the InitParameters if it is used when there is not InitSolution. Debug information wrongly claims that the default algorithm is used when dragging. This can not be true, as dragging is solved with the two subsystem solution, as there are priority constraints with negative tags for programatic moves. | ||||
