0003731GCSGeneralpublic2021-02-06 06:31
Reporterabdullah Assigned Toabdullah
PrioritynormalSeverityminorReproducibilityN/A
Status assignedResolutionopen
Product Version0.18
Target Version0.20
Summary0003731: SQP usage / debug information
Description
SQP appears not to be used for movement. It is unclear why it uses the InitParameters if it is used when there is not InitSolution.
Debug information wrongly claims that the default algorithm is used when dragging. This can not be true, as dragging is solved with the two subsystem solution, as there are priority constraints with negative tags for programatic moves.
yorik
2022-03-03 13:55
administrator   ~0016682
This ticket has been migrated to GitHub as issue 5847.
2018-12-15 18:38 abdullah New Issue
2018-12-15 18:38 abdullah Status new => assigned
2018-12-15 18:38 abdullah Assigned To => abdullah
2020-11-10 12:56 abdullah Target Version 0.19 => 0.20
2021-02-06 06:31 abdullah Target Version => 0.20
