| 0000374 | FreeCAD | Bug | public | 2011-06-08 22:03 | 2011-06-14 17:49 |
| Reporter | tombrown19 | Assigned To | yorik | ||
| Summary | 0000374: Snap does not always work | ||||
| Description | AMD 9850 Foxconn A7DA-S (790GX/SB750) 8GB RAM 17 x 2TB WD Caviar Green (16 in a ZFS - ZRAID1 array) 1 x 64GB Kingston SSDNow V+ SNVP325S264GB: Software: Distribution: ArchLinux Kernel: 2.6.37 (vanilla) xorg: xorg-server 1.10.2-1 KDE: 4.6.3-1 FreeCAD: 0.12 (4545) Description: At certain times, snap with <Ctrl> does not work. I believe this bug is not specifically drafting related but I have an example that is reproducible with the 2d Drafting workbench so this is how I am describing the problem. Reproducibility: - Open the file I have attached - Select the 2d Drafting workbench - Select the Draft -> line - Hold down <Ctrl> and try to snap to the wire object (it doesn't work when I try it) | ||||
2011-06-08 22:03
Try it without CTRL. Does it snap then? |
Your wire is not selectable. Therefore, you cannot snap to it. Check its "selectable" property, it is set to false. Probably some wrong manipulation you did... Setting that property to "true" makes the wire snappable again. Do not hesitate to reopen this issue if the problem is still there... |
| 2011-06-08 22:03 | tombrown19 | New Issue | |
| 2011-06-08 22:03 | tombrown19 | File Added: House.fcstd | |
| 2011-06-09 12:15 | pperisin | Note Added: 0000894 | |
| 2011-06-14 17:46 | yorik | Status | new => assigned |
| 2011-06-14 17:46 | yorik | Assigned To | => yorik |
| 2011-06-14 17:49 | yorik | Note Added: 0000900 | |
| 2011-06-14 17:49 | yorik | Status | assigned => closed |
| 2011-06-14 17:49 | yorik | Resolution | open => no change required |
| 2011-06-14 17:49 | yorik | Fixed in Version | => 0.12 |
