| 0003791 | GCS | General | public | 2019-01-24 13:57 | 2021-02-06 06:31 |
| Summary | 0003791: Solver fails to find redundancy | ||||
| Description | Forum discussion. | ||||
Here is another example of the Solver (in this example, DogLeg) failing to find redundancy. https://forum.freecad.org/viewtopic.php?f=3&t=39233#p333307 File is attached to the first post of the forum topic. Steps to reproduce: Open Sketch and drag a vertical line segment a bit. Apply a Horizontal Distance Constraint of 8 mm to the horizontal line segment. Apply Tangency Constraints between the arc and the vertical line segments. Delete whichever Vertical Constraint the Solver flags as redundant. Result: 1 DOF remains (the horizontal lone segment can be moved vertically) but the Solver fails to detect that the Horizontal Distance Constraint of 8 mm is redundant. |
This ticket has been migrated to GitHub as issue 5870. |
| 2019-01-24 13:57 | chrisb | New Issue | |
| 2019-01-24 13:57 | chrisb | Status | new => assigned |
| 2019-01-24 13:57 | chrisb | Assigned To | => abdullah |
| 2019-01-24 13:58 | chrisb | Description Updated | |
| 2019-09-11 15:48 | bejant | Note Added: 0013578 | |
| 2019-09-11 22:01 | bejant | Note Edited: 0013578 | |
| 2020-11-10 12:56 | abdullah | Target Version | 0.19 => 0.20 |
