| 0003801 | TechDraw | Bug | public | 2019-01-27 03:59 | 2019-02-10 12:40 |
| Reporter | uwestoehr | Assigned To | wandererfan | ||
| Summary | 0003801: impossible to specify custom projection view values - body will be deleted instead | ||||
| Description | I found a severe bug in FreeCAD Windows 7 64-bit, Version: 0.18.15694 (Git) - create a drawing from a body of your choice and select as template "A2_Landscape_ISO7200TD.svg" - use the menu TechDraw-> Insert Projection Group - double click in the field for the Primary view selection to modify it. For example in my case I see there: [0,96 -0,27 -0,05] and I need [0,75 -0,27 -0,05] thus I double click on the "96" and press DEL to be able to input the desired "75" afterwards result: I get a strange warning, see attached screenshot I don't want to delete anything, just remove the numbers to input new ones. final result: the pressing Yes in the warning dialog, I don't get the desired projection and, more severe, my body is deleted! So my body will be deleted despite I just wanted to delete a number in the projection view settings. p.s. I tried to report this first to the Open discussion forum but the software only tells me "You cannot make another post so soon after your last." but https://forum.freecadweb.org/search.php?search_id=egosearch tells me that I have not made any post. (which is obviously correct) | ||||
| Tags | TechDraw | ||||
Today I could post to the forum. Here is the thread: https://forum.freecadweb.org/viewtopic.php?f=35&t=33776 |
This bug was confirmed in the mentioned forum thread. |
The "current primary view direction" field is display only, it can not be used to change the direction. Primary View direction should be changed in the PropertyEditor if specific values are required. Select the "Front" View, then modify the Direction property. The dialog has been changed so that "current primary view direction" can not receive focus in commit commit 0f00402201. |
| 2019-01-27 03:59 | uwestoehr | New Issue | |
| 2019-01-27 03:59 | uwestoehr | Tag Attached: TechDraw | |
| 2019-01-27 03:59 | uwestoehr | File Added: projection-view-warning.jpg | |
| 2019-01-27 14:48 | uwestoehr | Note Added: 0012534 | |
| 2019-01-27 21:19 | uwestoehr | Note Added: 0012536 | |
| 2019-01-30 14:09 | wandererfan | Note Added: 0012562 | |
| 2019-01-30 14:11 | wandererfan | Assigned To | => wandererfan |
| 2019-01-30 14:11 | wandererfan | Status | new => resolved |
| 2019-01-30 14:11 | wandererfan | Resolution | open => fixed |
| 2019-01-30 14:11 | wandererfan | Fixed in Version | => 0.18 |
| 2019-01-30 14:11 | wandererfan | Target Version | => 0.18 |
| 2019-02-10 12:40 | wmayer | Status | resolved => closed |
