| 0003810 | TechDraw | Bug | public | 2019-01-29 20:08 | 2019-02-14 20:42 |
| Reporter | uwestoehr | Assigned To | wandererfan | ||
| Priority | normal | Severity | tweak | Reproducibility | have not tried |
| Summary | 0003810: ProjGroup setting Position can be changed when position is locked | ||||
| Description | - select a body and create a new drawing page - use the menu TechDraw -> Insert Projection Group to create a projected view - now select the ProjGroup and go into the property window - set the LockPosition to true result: FC allows me to change the x- and y-position but since the position is locked these fields should be disabled | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?p=283111#p283111 Windows 7 64-bit, Version: 0.18.15711 (Git) | ||||
| 2019-01-29 20:08 | uwestoehr | New Issue | |
| 2019-02-14 20:42 | wmayer | Assigned To | => wandererfan |
| 2019-02-14 20:42 | wmayer | Status | new => closed |
| 2019-02-14 20:42 | wmayer | Resolution | open => fixed |
| 2019-02-14 20:42 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-14 20:42 | wmayer | Note Added: 0012638 |
