| 0003814 | FEM | Bug | public | 2019-02-03 20:21 | 2019-02-10 12:17 |
| Reporter | uwestoehr | Assigned To | berndhahnebach | ||
| Summary | 0003814: FEM, FC becomes unusable after inserting certain constraints | ||||
| Description | Version: 0.18.15780 (Git) To reproduce: - create a new document, there create a simple body, e.g. a block - create a new simulation - now insert either * ElectrostaticPotential * ConstraintInitialFlowVelocity * ConstraintFlowVelocity As result one get an error like this one: The error messages are the same: File "C:\Users\USti\Desktop\FreeCAD_0.18.15780_Conda_Py3QT5-WinVS2015_x64\Mod\Fem\femguiobjects\_ViewProviderFemConstraintInitialFlowVelocity.py", line 51, in setEdit task = _TaskPanel(vobj.Object) File "C:\Users\USti\Desktop\FreeCAD_0.18.15780_Conda_Py3QT5-WinVS2015_x64\Mod\Fem\femguiobjects\_ViewProviderFemConstraintInitialFlowVelocity.py", line 69, in __init__ self._mesh = FemUtils.getSingleMember(analysis, "Fem::FemMeshObject") - now try to double click e.g. on a solver in the model tree. result: you get the message that there is a dialog active. But there is no active task and no open dialog. Working with FEM becomes impossible. workaround: right-click on the constraint in the model view and then chose "Finish Editing" | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?f=18&t=33944 | ||||
https://github.com/FreeCAD/FreeCAD/pull/1944/commits/f2a917699583e869eda7a0d804e6b8bc984a6515 |
Many thanks, your commit fixed the problem. So this bug can be marked as fixed. |
| 2019-02-03 20:21 | uwestoehr | New Issue | |
| 2019-02-03 20:27 | berndhahnebach | Note Added: 0012579 | |
| 2019-02-03 20:28 | berndhahnebach | Summary | FC becomes unusable after inserting certain constraints => FEM, FC becomes unusable after inserting certain constraints |
| 2019-02-09 00:02 | uwestoehr | Note Added: 0012595 | |
| 2019-02-10 12:17 | wmayer | Assigned To | => berndhahnebach |
| 2019-02-10 12:17 | wmayer | Status | new => closed |
| 2019-02-10 12:17 | wmayer | Resolution | open => fixed |
| 2019-02-10 12:17 | wmayer | Fixed in Version | => 0.18 |
