| 0003824 | FreeCAD | Bug | public | 2019-02-08 23:22 | 2019-02-26 20:53 |
| Reporter | uwestoehr | Assigned To | berndhahnebach | ||
| Summary | 0003824: Material editor: Meta -> Source property not saved | ||||
| Description | The material property Meta -> Source is not saved: - add a material, then "use FreeCAD material editor" - load a FCMat file - change or add something in the property Meta -> Source - Save it under a new FCMat file name - press OK and again click on "use FreeCAD material editor" - load the just saved FCMat file result: the value for Meta -> Source is lost, the field is empty | ||||
| Additional Information | forum thread: https://forum.freecadweb.org/viewtopic.php?f=38&t=34015 OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15805 (Git) Build type: Release Branch: master Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 | ||||
| Tags | material | ||||
| 2019-02-08 23:22 | uwestoehr | New Issue | |
| 2019-02-08 23:22 | uwestoehr | Tag Attached: material | |
| 2019-02-26 12:32 | uwestoehr | Note Added: 0012773 | |
| 2019-02-26 18:29 | wmayer | Target Version | => 0.18 |
| 2019-02-26 20:53 | wmayer | Assigned To | => berndhahnebach |
| 2019-02-26 20:53 | wmayer | Status | new => closed |
| 2019-02-26 20:53 | wmayer | Resolution | open => fixed |
| 2019-02-26 20:53 | wmayer | Fixed in Version | => 0.18 |
