| 0003832 | PartDesign | Bug | public | 2019-02-12 07:05 | 2019-02-16 15:32 |
| Reporter | chrisb | Assigned To | wmayer | ||
| Summary | 0003832: Editing thickness in Part or PartDesign resets join type to always being Arc | ||||
| Description | On editing an existing thickness feature (in PartDesign) or Object (in Part) the Join type is always reset to Arc, independent from the value set before. To reproduce: - create default cube - select one face - apply thickness - leave all parameters except JoinType which is set to "Intersection" - Ok, Thickness is applied, corners are not round. - Edit thickness with double click in the tree view Now JoinType is reset to Arc, which causes problems if applied unattended. There is a discussion in the german forum. OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15780 (Git) Build type: Release Branch: master Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: German/Germany (de_DE) | ||||
| 2019-02-12 07:05 | chrisb | New Issue | |
| 2019-02-12 07:07 | chrisb | Description Updated | |
| 2019-02-16 15:32 | wmayer | Assigned To | => wmayer |
| 2019-02-16 15:32 | wmayer | Status | new => closed |
| 2019-02-16 15:32 | wmayer | Resolution | open => fixed |
| 2019-02-16 15:32 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-16 15:32 | wmayer | Note Added: 0012664 |
