| 0003835 | FreeCAD | Bug | public | 2019-02-14 11:34 | 2019-02-14 11:37 |
| Reporter | uwestoehr | Assigned To | wmayer | ||
| Summary | 0003835: FC freezes when editing export STEP preferences | ||||
| Description | - start FC - use the Part WB or PartDesign WB - use menu Edit -> Preferences -> Import-Export -> STEP - there write into the 'author' field text with an umlaut, e.g. 'stöhr" - press Apply result: FC freezes. There is no output in the message panel. Finally one has to kill FC because it is not responding and unusable, no matter how long you wait. It seems to be an unfinished loop because the FC uses the full CPU power of one CPU core as soon as you press Apply. There is no but if there is no umlaut in the author field. Interestingly other non-ASCII characters don't trigger the freeze, e.g. using 'µ' or '³' work. However since my name contains an umlaut I want to use it of course. If this is not possible FC must tell me about and prevent the input of not allowed character. | ||||
| Additional Information | confirmed by 2 other users, forum thread: https://forum.freecad.org/viewtopic.php?f=3&t=34180 FreeCAD: 64-bit Version: 0.18.15860 (Git) | ||||
| 2019-02-14 11:34 | uwestoehr | New Issue | |
| 2019-02-14 11:37 | wmayer | Assigned To | => wmayer |
| 2019-02-14 11:37 | wmayer | Status | new => closed |
| 2019-02-14 11:37 | wmayer | Resolution | open => fixed |
| 2019-02-14 11:37 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-14 11:37 | wmayer | Note Added: 0012634 |
