| 0003845 | PartDesign | Bug | public | 2019-02-18 14:20 | 2019-02-19 08:52 |
| Reporter | uwestoehr | Assigned To | wmayer | ||
| Summary | 0003845: unwanted rounding for dimensions of subtractive shapes in task dialog | ||||
| Description | The radius of a subtractive cylinder. Its radius should be exactly 0.525 mm. But as you can see in the attached simple example. I can set the radius to 0.525 but after I pressed OK and then subsequently double-click in the cylinder whose radius I just set I see again 0.53 I use already 3 digits in the FC preferences and also using 4 digits does not solve my problem. It turned out that this is an issue of the task dialog because when you edit the radius directly in the Data tab of the combo view, I get the value I want. | ||||
| Additional Information | forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=34292 OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15860 (Git) Build type: Release Branch: master Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
This is not only a display issue since the unwanted rounding appears also in a Techdraw drawing. |
https://github.com/FreeCAD/FreeCAD/commit/638845a6f0159514ecf73813027b54197b1c3e7b |
| 2019-02-18 14:20 | uwestoehr | New Issue | |
| 2019-02-18 15:40 | uwestoehr | Note Added: 0012676 | |
| 2019-02-19 08:46 | wmayer | Severity | tweak => minor |
| 2019-02-19 08:52 | wmayer | Assigned To | => wmayer |
| 2019-02-19 08:52 | wmayer | Status | new => closed |
| 2019-02-19 08:52 | wmayer | Resolution | open => fixed |
| 2019-02-19 08:52 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-19 08:52 | wmayer | Note Added: 0012682 |
