0003846FreeCADBugpublic2019-02-19 14:56
Reporterlvch Assigned Towmayer
Status closedResolutionfixed
Product Version0.17
Fixed in Version0.18
Summary0003846: unexpected result in building RuledSurface
DescriptionMinor x-coordinate changes
the first point of two closed wires lead to an unexpected result
see more
https://forum.freecad.org/viewtopic.php?f=22&t=34211#p286871
Steps To Reproducerun the script (file #1)
result : file 0000002
Additional InformationMany small changes in x0 and x1 lead to the same result. For example,
increase or decrease x0 several times (not more than 2,4,6),
simultaneous change of the x0 and x1 signs.
Other minor changes give the right result.
For example, changing the sign of only x0, x0 = 0 or x1 = 0,
x0 = .1e-14, x0 = 1e-16, x0 = 0.0001
result: file 0000003
TagsApp::Part
Relationships
has duplicate 0003847 closed unexpected result in building RuledSurface
lvch
2019-02-18 14:27
reporter
err.FCMacro (688 bytes)
# -*- coding: utf-8 -*-
import FreeCAD
import Part
import Draft
x0 = 1.7256386715258160e-15
x1 = 1.4287545990052454e-15
# x0 *= 4*x0
# x1 *= 4*x1
x1=-x1
verts_0 =[(x0, -8., 0.), ( 0., -8., 2.), (-3., -8., 0.) ]
verts_1 =[(x1, -3., 0.), ( 0., -3., 2.), (-3., -3., 0.) ]
curva_0 = Part.makePolygon(map(FreeCAD.Vector,verts_0))
D0=Draft.makeWire(curva_0, closed=True,face=False)
curva_1 = Part.makePolygon(map(FreeCAD.Vector,verts_1))
D1=Draft.makeWire(curva_1, closed=True,face=False)
App.ActiveDocument.addObject("Part::RuledSurface","srf")
FreeCAD.ActiveDocument.ActiveObject.Curve1=D0
FreeCAD.ActiveDocument.ActiveObject.Curve2=D1
App.getDocument("_________________").recompute()
2019-02-19 14:56
administrator   ~0012695
https://github.com/FreeCAD/FreeCAD/commit/997d1d7d515f0551eb44d06da27df98288576ce2
2019-02-18 14:27 lvch New Issue
2019-02-18 14:27 lvch Tag Attached: App::Part
2019-02-18 14:27 lvch File Added: err.FCMacro
2019-02-18 14:27 lvch File Added: 1.png
2019-02-18 18:09 wmayer Relationship added has duplicate 0003847
2019-02-19 14:56 wmayer Assigned To => wmayer
2019-02-19 14:56 wmayer Status new => closed
2019-02-19 14:56 wmayer Resolution open => fixed
2019-02-19 14:56 wmayer Fixed in Version => 0.18
2019-02-19 14:56 wmayer Note Added: 0012695
