| 0003878 | Path | Feature | public | 2019-03-03 11:27 | 2019-06-11 02:03 |
| Reporter | slavekh1 | Assigned To | sliptonic | ||
| Priority | normal | Severity | minor | Reproducibility | random |
| Summary | 0003878: Path Workbench | ||||
| Description | Hello it would be greate to change the feed units from mm/s to mm/min this sound horrible and is not professional. For the rest you are doing a good work over there. | ||||
Internally, units are always stored in FreeCAD default units. That's mm for length and seconds for time. However, the user can select the metric, small parts, & CNC unit schema (preferences, Units, Unit system) and all operations will switch to user mm/min for velocity input. Post processors will output velocity as mm/min and most posts allow --inches to get in/min if desired. |
| 2019-03-03 11:27 | slavekh1 | New Issue | |
| 2019-06-11 02:03 | sliptonic | Assigned To | => sliptonic |
| 2019-06-11 02:03 | sliptonic | Status | new => closed |
| 2019-06-11 02:03 | sliptonic | Resolution | open => no change required |
| 2019-06-11 02:03 | sliptonic | Fixed in Version | => 0.18 |
| 2019-06-11 02:03 | sliptonic | Note Added: 0013177 |
