| 0000391 | PartDesign | Bug | public | 2011-06-25 19:07 | 2015-01-13 00:09 |
| Reporter | trojka | Assigned To | logari81 | ||
| Summary | 0000391: Pading of to surfaces | ||||
| Description | Pading to surfaces with partial overlapping leads to a strange shape. see attached screenshot | ||||
2011-06-25 19:07
Normaly the Pad should fail on overlaping sketch-lines. If we support such thing I would do a bolean operation in the sketch to allow a proper sketch shape... |
The user now get a appropriated error massage if pad fails... |
Set to closed. |
Sorry, but it's not fixed. When creating two overlapping rectangles and extrude them there is no error message but an invalid pad. |
Ok, we need a more extensive error checking, I will put that into the 0.13 |
PartDesign::SketchBased::makeFace creates a compound of faces from the sketch wires without checking for overlaps. But in Pad::execute() TopoDS::Face() chokes on this compound and throws an exception. Because the exception error string only says "TopoDS::Face" the catch() block of Pad::execute() changes this to a more lucid message. IMHO we can set this bug as resolved (and similar ones for Pocket,Revolution and Groove). See https://github.com/jrheinlaender/FreeCAD/commit/a3f011432766b4a42fcb24f890c0ce3e029b913c |
Move that problem to the 0.14 release |
2012-12-20 21:26
isn't this fixed in master? After jrheinlaenders enhancements padding up to face used to be quite robust, last time I checked. Some times there are seem lines left, but the refinement tool is able to remove them (see the attached file). |
Im actually not get much out of that example file!? So I put it one you, close it if you think its fixed... |
No bug view on 0.13 RC 1803 (win7) with the file link |
| 2011-06-25 19:07 | trojka | New Issue | |
| 2011-06-25 19:07 | trojka | File Added: Bug sketcher 012_4447.png | |
| 2011-06-26 06:31 |
Status | new => assigned |
| 2011-06-26 06:31 |
Assigned To | => Jriegel |
| 2011-06-26 06:32 |
Note Added: 0000916 | |
| 2011-09-16 04:47 |
Note Added: 0001088 | |
| 2011-09-16 04:47 |
Status | assigned => resolved |
| 2011-09-16 04:47 |
Fixed in Version | => 0.12 |
| 2011-09-16 04:47 |
Resolution | open => fixed |
| 2011-09-17 06:28 | wmayer | Note Added: 0001105 | |
| 2011-09-17 06:28 | wmayer | Status | resolved => closed |
| 2011-09-17 06:40 | wmayer | Note Added: 0001106 | |
| 2011-09-17 06:40 | wmayer | Status | closed => feedback |
| 2011-09-17 06:40 | wmayer | Resolution | fixed => reopened |
| 2011-09-17 06:40 | wmayer | Product Version | trunk => |
| 2011-11-10 12:43 |
Note Added: 0001270 | |
| 2011-11-10 12:44 |
Fixed in Version | 0.12 => |
| 2011-11-10 12:44 |
Target Version | => 0.13 |
| 2012-08-20 12:33 | jrheinlaender | Note Added: 0002326 | |
| 2012-12-20 11:11 |
Note Added: 0002675 | |
| 2012-12-20 11:11 |
Target Version | 0.13 => 0.14 |
| 2012-12-20 21:26 | logari81 | File Added: pad_up_to_face.fcstd | |
| 2012-12-20 21:28 | logari81 | Note Added: 0002717 | |
| 2012-12-20 22:32 |
Status | feedback => assigned |
| 2012-12-20 22:32 |
Assigned To | Jriegel => logari81 |
| 2012-12-20 22:33 |
Note Added: 0002734 | |
| 2013-01-02 22:42 | ryback08 | Note Added: 0002787 | |
| 2014-05-12 15:05 | wmayer | Project | FreeCAD => PartDesign |
| 2014-05-24 16:25 | yorik | Target Version | 0.14 => |
| 2015-01-13 00:09 | wmayer | Status | assigned => closed |
| 2015-01-13 00:09 | wmayer | Resolution | reopened => fixed |
