| 0003911 | TechDraw | Feature | public | 2019-03-20 02:05 | 2021-02-06 06:38 |
| Reporter | vocx | Assigned To | |||
| Summary | 0003911: Autofill information in SVG page template | ||||
| Description | In Catia the Drawing workbench auto-fills certain text fields in the Page Templates that come with the software. TechDraw could implement a similar behavior. The usage would be something like a button in the TechDraw toolbar to open a dialog with the fields that can be filled in the page template. It could also have a button in this dialog to automatically fill at least some values like Author, Date, Title, and Page. Another option would be to right click the field in the page itself (highlighted in green) to display the options (Author, Title, Page, etc.) which will to fill the field. In order to implement this well, each SVG template provided by FreeCAD should conform to some standardized name for the editable fields, for example, FC_AUTHOR, FC_DATE, FC_TITLE, etc. The data to write in the fields can be taken from the General Preferences of the Document, or taken from a Spreadsheet, or calculated by Qt in some way. The discussion is on the forum https://forum.freecadweb.org/viewtopic.php?f=35&t=31681 | ||||
| Additional Information | OS: Ubuntu 18.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16093 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce Python version: 2.7.15rc1 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| Tags | SVG, TechDraw | ||||
|  | additional forum discussion |
|  | I think - this small but very need function. I add screenshots about this feature. May be - this order: 1. Create list of standard field's names, 2. Add option in TechDraw setting - "Insert information for page", 3. Change all template (rename all fields), |
|  | This ticket has been migrated to GitHub as issue 5903. |
| 2019-03-20 02:05 | vocx | New Issue | |
| 2020-01-05 12:46 | wandererfan | Note Added: 0013982 | |
| 2020-01-05 20:53 | svbol | File Added: TD_AutoDate1.png | |
| 2020-01-05 20:53 | svbol | File Added: TD_AutoDate2.png | |
| 2020-01-05 20:53 | svbol | Note Added: 0013983 | |
| 2020-01-05 20:54 | svbol | Tag Attached: TechDraw | |
| 2020-01-05 20:55 | svbol | Tag Attached: SVG | |
| 2020-01-05 21:09 | svbol | Note Edited: 0013983 | |
| 2020-01-05 21:11 | svbol | File Added: TD_AutoDate3.png | |
