| 0003914 | Path | Bug | public | 2019-03-20 23:42 | 2021-02-06 06:33 |
| Reporter | sliptonic | Assigned To | |||
| Summary | 0003914: Path Stock using Existing Solid not maintaining state | ||||
| Description | When the user chooses to use an existing solid as the stock object for a Job, the behaviour is inconsistent and confusing. 1) The user selects 'use existing solid' from the combobox. 2) The user picks the solid from the list of available choices. 3) If the user presses 'refresh' at this point, the choice to use existing solid remains but the selected solid switches to the first one in the list. 4) If the user selects a solid (other than the first) and then closes the Job task panel, everything is fine. But if the Job is re-opened, the selected solid switches back to the first in the list again. | ||||
FreeCAD: master 8c3bad64 2020-12-13 19:52:32 Details Diff |
Path: Fix 0003914: Adding stock label prefix to name comparison in order to select correct existing solid in combo box |
Affected Issues 0003914 |
| mod - src/Mod/Path/PathScripts/PathJobGui.py | Diff File | ||
FreeCAD: master ef2e209b 2021-01-27 17:09:31 Committer: GitHub Details Diff |
Merge pull request 0004140 from gauna85/PathStock Path: Fix 0003914: Adding stock label prefix to name comparison in orde⦠|
| 2019-03-20 23:42 | sliptonic | New Issue | |
| 2020-12-13 19:55 | gauna | Note Added: 0015136 | |
| 2021-01-27 17:30 | sliptonic | Changeset attached | => FreeCAD master ef2e209b |
| 2021-01-27 17:30 | gauna | Changeset attached | => FreeCAD master 8c3bad64 |
| 2021-01-27 17:30 | gauna | Note Added: 0015223 | |
| 2021-02-06 06:33 | abdullah | Target Version | => 0.20 |
