| 0003929 | GCS | General | public | 2019-04-07 04:11 | 2021-02-06 06:31 |
| Reporter | abdullah | Assigned To | abdullah | ||
| Summary | 0003929: SQP linear search second order step | ||||
| Description | PVS discovered that the second order step of the linear search of SQP was apparently initially intended by logari to be executed once, but it is executed in each iteration. A solution should be found, but requires building tests to evaluate the performance. https://forum.freecadweb.org/viewtopic.php?f=10&t=35469#p299489 | ||||
