0003943PartDesignBugpublic2021-02-06 06:43
Reporterjmaustpc Assigned To
Status newResolutionopen
PlatformAMD64OSKubuntuOS Version18.04
Product Version0.18
Target Version0.20
Summary0003943: Disable auto hide solid option when entering Sketch edit mode sets and leaves solid hidden
DescriptionIn PartDesign, if you enter edit mode of a feature's sketch, by default the solid will be set to hidden so that the solid will not obscure the sketch. There is a property of the sketch to disable this feature as well as a setting in preferences to change the default value of that property.
When the property is set to disable this auto hide function, FreeCAD still hides the solid and also leaves the solid hidden when you close sketch edit mode.
The first feature seems to work correctly but subsequent features show this bug.
https://forum.freecad.org/viewtopic.php?p=303218#p303218
Steps To ReproduceIn the file attached, try toggling the "Hide Dependent" property of the three sketches then double click so that the sketch goes into edit mode.
The first sketch will hide or not hide the solid and then if it was hidden it returns it to visible after closing sketch edit mode.
however the subsequent sketches when "Hide Dependent" is set to false, 1) the feature related to that sketch is firstly hidden anyway, and then when edit mode is closed, the solid remains hidden
Additional InformationOS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
Locale: English/Australia (en_AU)
jmaustpc
2019-04-24 17:13
manager
hiding_1_mod.FCStd (22,532 bytes)
yorik
2022-03-03 13:55
administrator   ~0016753
This ticket has been migrated to GitHub as issue 5919.
2019-04-24 17:13 jmaustpc New Issue
2019-04-24 17:13 jmaustpc File Added: hiding_1_mod.FCStd
2021-02-06 06:43 abdullah Target Version => 0.20
