| 0003947 | FreeCAD | Bug | public | 2019-04-27 10:49 | 2021-02-06 06:50 |
| Reporter | seppelw | Assigned To | |||
| Platform | x86 64 Bit | OS | Windows | OS Version | 7 and 10 |
| Summary | 0003947: Part-Container: Moved Part-Container do not effect contained objects | ||||
| Description | FreeCAD is not able to handle Objects in moved Part-Container and always refers to the origin of the object in the container. https://forum.freecad.org/viewtopic.php?f=3&t=35938 | ||||
| Steps To Reproduce | Bug: 1) Add 3 Solids, Cube, Cylinder, Cone 2) Place each in an individual part 3) Move the parts 4) Set the current working plane to the face of the Cube Result) FreeCAD is not able to work with Part-container There is no reason why that should happen. | ||||
P.S. As openBrain concluded: .....the pity is that FC misses the feature of being able to work inside an active part container. |
Part-containers with it's placement should allow nesting and the actual position in space of the actual object should be calculated accordingly(derived). For visualization that is the case, when moving the part-container the displayed solid in it moves according to the move of the part-container. However, when it comes to shape-binders, working-planes etc. the behaviour does not match the display-position/behaviour, it is implemented differently, the functions use a wrong position. The display is correct but the functions such as working-plane, shape-binders use a falsely calculated position, different from the display breaking the WYSIWYG concept. |
OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16093 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) |
This ticket has been migrated to GitHub as issue 5920. |
| 2019-04-27 10:49 | seppelw | New Issue | |
| 2019-04-27 10:49 | seppelw | File Added: Bug_2.FCStd | |
| 2019-04-27 10:49 | seppelw | File Added: Bug_2.png | |
| 2019-04-27 11:08 | seppelw | Note Added: 0013060 | |
| 2019-04-27 13:08 | seppelw | Note Added: 0013067 | |
| 2019-07-14 19:28 | seppelw | Note Added: 0013343 | |
