0003947FreeCADBugpublic2021-02-06 06:50
Reporterseppelw Assigned To
Status newResolutionopen
Platformx86 64 BitOSWindowsOS Version7 and 10
Product Version0.18
Target Version0.20
Summary0003947: Part-Container: Moved Part-Container do not effect contained objects
DescriptionFreeCAD is not able to handle Objects in moved Part-Container and always refers to the origin of the object in the container.
https://forum.freecad.org/viewtopic.php?f=3&t=35938
Steps To ReproduceBug:
 1) Add 3 Solids, Cube, Cylinder, Cone
 2) Place each in an individual part
 3) Move the parts
 4) Set the current working plane to the face of the Cube
 Result) FreeCAD is not able to work with Part-container
 There is no reason why that should happen.
seppelw
2019-04-27 10:49
reporter
Bug_2.FCStd (8,217 bytes)
seppelw
2019-04-27 11:08
reporter   ~0013060
P.S. As openBrain concluded: .....the pity is that FC misses the feature of being able to work inside an active part container.
seppelw
2019-04-27 13:08
reporter   ~0013067
Part-containers with it's placement should allow nesting and the actual position in space of the actual object should be calculated accordingly(derived).
For visualization that is the case, when moving the part-container the displayed solid in it moves according to the move of the part-container. However, when it comes to shape-binders, working-planes etc. the behaviour does not match the display-position/behaviour, it is implemented differently, the functions use a wrong position.
The display is correct but the functions such as working-plane, shape-binders use a falsely calculated position, different from the display breaking the WYSIWYG concept.
seppelw
2019-07-14 19:28
reporter   ~0013343
OS: Windows 10
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 3.6.6
Qt version: 5.6.2
yorik
2022-03-03 13:55
administrator   ~0016754
This ticket has been migrated to GitHub as issue 5920.
2019-04-27 10:49 seppelw New Issue
2019-04-27 10:49 seppelw File Added: Bug_2.FCStd
2019-04-27 10:49 seppelw File Added: Bug_2.png
2019-04-27 11:08 seppelw Note Added: 0013060
2019-04-27 13:08 seppelw Note Added: 0013067
2019-07-14 19:28 seppelw Note Added: 0013343
2021-02-06 06:50 abdullah Target Version => 0.20
