| 0003990 | FreeCAD | Bug | public | 2019-05-28 18:31 | 2021-02-06 06:50 |
| Reporter | bzb.dev001 | Assigned To | |||
| Summary | 0003990: Placement dialog fails after click on 3d view | ||||
| Description | When the Placement dialog is opened, clicking on 3d view and using the number key to select a different view, causes the dialog box to be inoperative. Ie. changing values in the Placement dialog does not correspond to positional changes in the solid in 3d view. reference discussion: https://forum.freecadweb.org/viewtopic.php?f=3&t=36665 | ||||
| Steps To Reproduce | Create Body Create a sketch Create Pad feature on sketch. Click on Body in Combo view Open Placement dialog changing translation values for x,y,z show solid moving in 3d view...This is expected click on some area in 3d view now change translation values for x,y,z...Notice the solid does not move to correspond to new specified position Changing any value in both the Translation section, Center section and Rotation section of dialog does nothing If I were to click on "selected points" button, a notification message is shown. Once I click on the "ok" button to close it, changing the values in Center section of Placement dialog cause the solid to move. This is unexpected. | ||||
| Additional Information | OS: Ubuntu 18.04.2 LTS (LXDE/Lubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.16718 (Git) AppImage Build type: Release Branch: master Hash: cfd04ac6afa091f5c4f18e94756bd58fb6d66806 Python version: 3.7.1 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Canada (en_CA) | ||||
| 2019-05-28 18:31 | bzb.dev001 | New Issue | |
| 2019-05-29 19:33 | Kunda1 | Status | new => confirmed |
| 2019-05-29 19:33 | Kunda1 | Note Added: 0013126 | |
| 2019-05-29 19:33 | Kunda1 | Target Version | => 0.19 |
