| 0004011 | Path | Bug | public | 2019-06-07 14:58 | 2019-06-10 14:40 |
| Reporter | freman | Assigned To | sliptonic | ||
| Summary | 0004011: no pocket path is diam=tool diam | ||||
| Description | https://forum.freecadweb.org/viewtopic.php?f=15&t=36891 making an edge pocket path on a circle with a tool equal to that of the circle fails to produce a path. eg 6mm end mill: 3mm rad hole: no path 3.001mm : no path 3.01 : path with very small arc cut. | ||||
| Steps To Reproduce | make sketch with 3mm rad hole pad create edge pocket path using 6mm tool result : no path to hole, no hole. Increase hole size until path tool works. | ||||
| Additional Information | OS: Linux (LXDE/LXDE) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.16854 (Git) Build type: Release Branch: master Hash: fe0fd5512ba9a8a9c729cdc47af35bbe965050ac Python version: 2.7.15 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
| 2019-06-07 14:58 | freman | New Issue | |
| 2019-06-10 14:40 | sliptonic | Assigned To | => sliptonic |
| 2019-06-10 14:40 | sliptonic | Status | new => closed |
| 2019-06-10 14:40 | sliptonic | Resolution | open => no change required |
| 2019-06-10 14:40 | sliptonic | Fixed in Version | => 0.19 |
| 2019-06-10 14:40 | sliptonic | Note Added: 0013171 |
