| 0004018 | PartDesign | Bug | public | 2019-06-13 14:09 | 2020-11-27 20:02 |
| Reporter | berka | Assigned To | wmayer | ||
| Platform | x64 | OS | MacOS | OS Version | Mojave 10.14.5 |
| Summary | 0004018: Proximity point attachment between plane and line does not work | ||||
| Description | DatumPoint can't be attached to a line/plane intersection. To achieve, I'm using: A Datum Plane A Datum Line (not on plane) A Datum Point When trying to attach the Datum Point (select the Plane+Line as references), the proximity point attachment fails with message:
Possibly related bug: 0003921 Forum Topic (starts differently): https://forum.freecadweb.org/viewtopic.php?f=3&t=36920 Reported reproduced on V0.19 as well by @chrisb. | ||||
| Steps To Reproduce | You can try this file: ellipseprojection.FCStd 1) Create a datum point 2) Select "DatumPlane Offset Incline" as a reference 3) Select "DatumLine Ridge" as a second reference 4) Try "Proximity Point 1" as Attachment mode. The order of references doesn't matter. Proximity point 2 also does the same. Alternately, you can start from a new file: 1) Create body 2) Create a Datum Plane (I used detached) 3) Create a Datum Line 4) Create a Datum point and try proximity point as above. | ||||
| Additional Information | OS: macOS 10.14 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16117 (Git) Build type: Release Branch: (HEAD detached at 0.18.2) Hash: dbb4cc6415bac848a294f03b80f65e888d531742 Python version: 3.6.7 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
| 2019-06-13 14:09 | berka | New Issue | |
| 2019-06-13 14:09 | berka | File Added: ellipseprojection.FCStd | |
| 2019-06-13 14:51 | Kunda1 | Description Updated | |
| 2019-06-13 14:56 | Kunda1 | Status | new => confirmed |
| 2019-06-13 14:56 | Kunda1 | Target Version | => 0.19 |
| 2020-11-27 17:57 | abdullah | Assigned To | => wmayer |
| 2020-11-27 17:57 | abdullah | Status | confirmed => closed |
| 2020-11-27 17:57 | abdullah | Resolution | open => fixed |
| 2020-11-27 17:57 | abdullah | Fixed in Version | => 0.19 |
| 2020-11-27 20:01 | Kunda1 | Relationship added | related to 0004169 |
| 2020-11-27 20:02 | Kunda1 | Relationship added | related to 0003921 |
