0004032GCSBugpublic2021-02-06 06:31
Reporterchrisb Assigned Toabdullah
Status assignedResolutionopen
Target Version0.20
Summary0004032: Solver claims Sketch to be fully constrained which it isn't
DescriptionSee forum topic. The left vertical line of the sketch can be moved horizontally.
After removing the lower 0mm distance the solver even claims the sketch to be overconstraint.
bejant
2019-09-11 14:40
reporter   ~0013574
Here is another example of the Solver mistakenly arriving at a Fully Constrained solution when in fact 1 DOF remains in that the upper endpoints of the vertical line segments, and the entire horizontal line segment, can be moved vertically. File is attached in the first post of the forum topic.
https://forum.freecad.org/viewtopic.php?f=3&t=39233#p333307
yorik
2022-03-03 13:55
administrator   ~0016785
This ticket has been migrated to GitHub as issue 5951.
2019-06-20 22:16 chrisb New Issue
2019-06-20 22:16 chrisb Status new => assigned
2019-06-20 22:16 chrisb Assigned To => abdullah
2019-09-11 14:40 bejant Note Added: 0013574
2019-09-11 14:56 bejant Note Edited: 0013574
2019-09-11 15:11 bejant Note Edited: 0013574
2019-09-11 22:00 bejant Note Edited: 0013574
2020-11-10 12:56 abdullah Target Version 0.19 => 0.20
2021-02-06 06:31 abdullah Target Version => 0.20
